Radiator Fan Control and the Ecuflash
Postby evo85MR » Tue Jun 10, 2008 7:33 am
Hi everyone! I am new here! I own an 2004 JDM EVO8.5 MR and I have the following question that wants to ask:
In general, is that a possibility to screw the opearation of my car's radiator fan if I used a wrong description to flash a rom to my car?
My problem now is: It seems my radiator fan doesn't turn on even my coolant temperature rised to 100 degree C. I checked the rom and if I am correct the fan should be turn on at around 88 or 90 sth...
I drove my car to my mechanics to check the fan and relay and it seems all fine.
Experts please check with me the attached description and rom to see if it's correct for my car? Thanks a lot!
97250001.xml
(8.92 KiB) Downloaded 617 times
04_LANCER_EVO8_GSR_Ralliart_MT_97250001.hex
(256 KiB) Downloaded 633 times
evo85MR
Postby grayw » Sun Jun 15, 2008 3:26 am
The rom you have posted is for a normal JDM VIII NOT an MR. You will also have lost boost control from the second solenoid also.
Flash back your original rom....
grayw
