evo 8 ecu part# MN132750! please help
Postby clip14 » Wed Apr 30, 2008 11:54 am
Hi
I just bought an evo 8 ecu with the part number MN132750
I just want to check whether it actually is an evo 8 ecu!?
can someone run this through CAPS or confirm that it is the ecu?
it is a black box with only 3 plugs. I was under the impression that the ecu's had 4 plugs???
clip14
Postby todd-w » Wed Apr 30, 2008 12:56 pm
it is an evo8ecu , afaik only evo8 260 had four plugs, you can get a harness patch , three sockets to four plug same as used for power fc for three plug evo
todd-w
Postby clip14 » Wed Apr 30, 2008 12:59 pm
todd-w wrote:it is an evo8ecu , afaik only evo8 260 had four plugs, you can get a harness patch , three sockets to four plug same as used for power fc for three plug evo
awesome, thanks for that confirmation
Can you tell me where I can get this harness patch?
Cheers
clip14
Postby clip14 » Wed Apr 30, 2008 5:39 pm
i had a look around and it seems that there are harness patches to go from 3 plug -> 4 plug. but im looking for a harness patch that goes the other way. 4 -> 3
does anyone know where to find one of these?
I want to run the evo 8 ecu in an evo4 which is 4plug.
clip14
