HELP!! ecu
HELP!! ecu
Postby joyce1bro » Thu Apr 10, 2008 6:45 pm
Help!!!
ok so im wiring the evo 7 ecu into my E5 and when tring to pull out cable 20 so i can match it to pin 32... the wire ripped out of the harness leaving me with one ripped wire and one connector (which i should be using) left inside the harness.
how do i get those little connectors out??????? i tried using everything....
I first thought i could just cut the wire and connect to the wire that was at pin 32 but there was no wire!!!!
any suggestions????
joyce1bro
Postby joyce1bro » Fri Apr 11, 2008 2:06 am
sweet its been sorted
joyce1bro
