looking for Xml for 97470001
Postby christian_piasini » Fri Mar 07, 2008 2:30 pm
Hello have some one a complete xml definition for this rom?
N° 97470001
I find one but the load and rpm axis aren't right.
Thanks for any replay.
97470001.xml
(21.45 KiB) Downloaded 680 times
EVO8_97470001.hex
(256 KiB) Downloaded 675 times
Postby The WARLOCK » Sat Apr 19, 2008 4:07 am
I have the same problem , load and rpm are f**cked is this xml for 1.29a maybe?????
The WARLOCK
Postby The WARLOCK » Sat Apr 19, 2008 6:02 am
Problem found!!!!!!!
Convert all endian from little to big ,problem solved 8) :D :twisted:
if you use 1.34
The WARLOCK
Postby fel1979 » Wed Apr 23, 2008 7:31 pm
Hi,
I have tried this Definition, however I'm not quite sure that all values are imported.
Have anyone refreshed the ECU with this definition without problems?
It seens that are missing some table, eventhough there are more scroll down there, but I didn't find any Check Engine codes to disable.
Here it's how it looks for me..
PS: I have changed the endian, and the problem was fixed. :D
fel1979
Postby The WARLOCK » Wed Apr 30, 2008 7:39 am
Evo 's don't have check engine codes to de-program in ecuflash.
The WARLOCK
