Rom / def / xml file for EVO VIII FQ300 (UK)
Postby bassed » Tue Feb 19, 2008 10:41 am
Hi Everyone,
Please could someone suggest which XML file I should be using for my VIII FQ300 (UK).
Using ECUFLASH 1.34.
Many thanks in advance.
bassed
Postby S54fan » Tue Feb 19, 2008 10:53 am
I posted it on here before somewhere in this forum.
Postby bassed » Wed Feb 20, 2008 3:02 pm
S54fan wrote:I posted it on here before somewhere in this forum.
Ok, great thanks S45fan.
I'll do another search for post that have been performed by you.
Cheers
Mark
bassed
Postby todd-w » Thu Feb 21, 2008 1:11 pm
try here
93660005.xml
(11.95 KiB) Downloaded 793 times
todd-w
Postby Guest » Tue Jul 29, 2008 3:55 am
Thanks again S54fan. This has got me passed my first issue....
I've attached the data read from my ECU prior to tinkering!
I have an image that seems to enable launch control (also attached), but the map itself doesn't suit my car - how should I go about inserting/enabling the launch control/stationary rev limit feature on my original map?
Also, I'm looking to up the boost (to the mechanical limitations of the OEM solenoid) until I have the funds to put in an AVC-R. Have you seen success with this?
Evo 8 with LC enabled.bin
Modified program with LC
(256 KiB) Downloaded 700 times
OEM UK Evo VIII FQ-300 10-7-8 SRT.hex
My original program
(256 KiB) Downloaded 739 times
Guest
