How to change Scaling on ignition map.
Postby Malmoe_Sweden » Fri Feb 15, 2008 6:54 am
Need help with rescaling my ign map for higher boost
JDM 99860002 has got 260 as highest load. Need it to be rescaled to 300.
I know how to change elements but not how to get increased values on load scale.....280,300.
Help please.
Cheers Lars
Malmoe_Sweden
Postby burgers » Thu Mar 06, 2008 3:11 pm
Hey Lars, did you get this worked out? Let me know I can help if you need it.
MB
burgers
Postby GIVI EVO III » Thu Nov 13, 2008 10:17 pm
As I know, but it is possible that I'm wrong, it must be done this way: Open desirable map, go to "Edit"; at the buttom you will see "Edit map Definition", click on it and window will open; in this window you will see "X Axis Load"; it contains "Elements", you will see number 19, this is count of columns; so by increasing this value you will add to map load columns.
Hope this will help you. :wink:
Cheers
GIVI EVO III
Postby GIVI EVO III » Sun Nov 16, 2008 11:52 pm
Here is PDF file about rescaling, this is differen from what I have written.
http://www.aktivematrix.com/forum/kb.ph ... 144cd1e355
GIVI EVO III
