Need Help for EVO 9 JDM .. Again ... Thanks
Postby wrx-blue-mica » Fri Jan 18, 2008 11:21 am
Hi
Please help me to open this Evo 9 JDM file but no suitable XML file.
If not crash then the map open with wrong numbers. So I need the right XML Def File.
Memory Model: SH7055
Thank you for your attention & help
Evo 9 hitam.hex
(512 KiB) Downloaded 664 times
wrx-blue-mica
Postby wrx-blue-mica » Fri Jan 18, 2008 11:24 am
double post .. sorry
Last edited by wrx-blue-mica on Fri Jan 18, 2008 11:26 am, edited 1 time in total.
wrx-blue-mica
Postby wrx-blue-mica » Fri Jan 18, 2008 11:25 am
Have tried with this XML file 89980000.zip from other tread but no luck...:)
wrx-blue-mica
Postby todd-w » Fri Jan 18, 2008 2:16 pm
try this
deleted
todd-w
Postby wrx-blue-mica » Fri Jan 18, 2008 9:36 pm
todd-w wrote:try this
The Program Crash when use this XML file.
Thanks Tod but the ecuflash program crash and closed when I use this XML.
I dont know what cause it. If I remove this 88570008 from rommedata directory, ecuflash works normal again but can't read the rom file.
Any suggestion how to make it work or maybe is there any XML file that can make it work?
wrx-blue-mica
Postby todd-w » Sat Jan 19, 2008 4:45 pm
thats strange i can open your rom with it . anyone else download it have the same problem??????
todd-w
Postby wrx-blue-mica » Sat Jan 19, 2008 10:08 pm
todd-w wrote:thats strange i can open your rom with it . anyone else download it have the same problem??????
I have tried with my friend laptop too and we got the same result. When I opened the Rom FIle, the Ecuflash suddently closed and got the pop up message that the Ecuflash program has problem and blablabla ...
but if we move that XML file from rommedata everything worked normal again but couldn't read that Evo 9 rom file. But if I open other rom file like Evo 8 everything went normal too.
Me and my friend are using Ecuflash V1.33, are you using the same version too or different version?
Is it possible te v1.33 is the cause ?
thanks for your reply Todd & please help me with this strange problem...:)
wrx-blue-mica
Postby todd-w » Sun Jan 20, 2008 10:32 am
could you pm me your e-mail address.
todd-w
Postby wrx-blue-mica » Mon Jan 21, 2008 9:41 am
Just want to let you all know that finally my laptop can read this rom without any problem, no crash & no funky or funny numbers. Everything works normal now. It's all because of Todd help!
You are awesome bro .. thank you very much!! .. GBU ... :):)
wrx-blue-mica
Postby todd-w » Mon Jan 21, 2008 12:08 pm
8) glad to help .
todd-w
