evo IV to VI ecu
Tue Dec 11, 2007 11:55 am
by steve_s13
if one has an evo 4 but fitted with an evo 6 ecu can still still be read and flashed in the normal way?
im used to flash tuning EVO 8's but i used my normal tactrix cable and plugged in but it wouldnt read from the ECU.
Tue Dec 11, 2007 2:11 pm
by todd-w
no only way afaik to flash 5/6 ecu is with ecutek also need to run a wire to pin 79 for the white plug to do this,for evoscan you need to join pins 1 and 4 on obd socket. ive fitted an evo8 ecu to mine to get around this
Wed Dec 12, 2007 9:09 am
by steve_s13
so your saying I cannot flash an EVO 4 fitted with an EVO 6 ECU?
if you can. what the step by step process.
im still learning.... I have this extra white plug in addition to my cable and I can clearly see under the dash the two blade male adaptio which my female plug fits no problem.
but your saying I need to run another wire ??
Wed Dec 12, 2007 9:11 am
by steve_s13
So basically if you own an EVO 4,then Fit an EVO 8 ecu to get around any probs and dont waste time with and EVO 6 or even & ECU? is that what your saying??
Wed Dec 12, 2007 1:25 pm
by todd-w
if you have the white plug one problem solved have a read of this
http://forums.openecu.org/viewtopic.php ... highlight=
Re: evo IV to VI ecu
Tue Dec 22, 2009 8:23 am
by steve_s13
cheer Todd
got this one going over the weekend
you da man
Tue Dec 22, 2009 10:27 am
by todd-w
excellent steve good news m8
