by S54fan » Wed Dec 05, 2007 2:52 am
You can't safely tune especially on difficult fuel without a wideband, especially since some IX GSR are too lean on spool up with lean spool enable set to 3500 RPM and have dropped exhaust valves in standard trim.
With exhaust including O2 housing, airbox mod, AVC-R on my JDM IX GSR (FQ340 UK car) runs 1.8 bar from 2600-5600 RPM, 1.7 bar at 6000 RPM, 1.4 bar at 7000 RPM on 99 RON at 11.5:1 AFR, full MIVEC advance in spool and midrange and typically 3 or 4 degrees more ignition timing than standard JDM GSR with knock sums always 3 or less. Lean spool enable is 2000 RPM, disable is 7500 RPM to correct the fuelling anomalies the stock engine has on boost to 3500 RPM and the step richening at 7000 RPM (read more on evolutionm.net).
For items to log including load read up on evolutionm.net Ecuflash forum, there are lots of starter guides there.
