Air Flow Meter
Air Flow Meter
Postby Zakie@TIC » Tue Oct 02, 2007 9:43 am
I'm planning in running a EVO8 ecu on a evo4, its kinda hard to find a 8 AFM is it possible to use a AFM off a NA Cedia of the same vintage for this job. Regards
Zakie@TIC
Postby MalibuJack » Thu Oct 04, 2007 4:02 am
The AFM's are scaled differently, a bit of a hassle to get calibrated. I would check ebay or other sites and try to get an Evo8 sensor. You do have other options to run in place of the sensor, there is some development directly in the ECU to convert to speed density with a JDM MAP sensor (or GM 3 bar sensor) or you can use a piggyback device and a GM or Ford MAF sensor in a blowthrough configuration (ECU+ or MAFT+ or MaftPro are a few examples)
Unfortunately you'll have to start with a stock Evo8 sensor to be certain everything works right, so once you get that far, you might as well keep it.
MalibuJack
Postby Zakie@TIC » Thu Oct 04, 2007 4:09 am
Thanks for the info Malibujack, so you're confirming my doubt that a evo4 AFM will not work with the evo8 ecu swap.
Zakie@TIC
Postby blackbichGSX » Thu Oct 11, 2007 12:02 am
The Evo 8 and 2G DSM AFM are the same if you can get one. They should be on any DSM board for around $20-40.
blackbichGSX
Postby Zakie@TIC » Fri Oct 12, 2007 12:53 am
Thanks for the info
Zakie@TIC
