ROM / Definition file problem
Postby ghoonk » Sat Sep 15, 2007 8:15 am
Hi guys
I just tried downloading the map off my friend's brand new Evo 9, but ECUFlash has come back with a message saying that it does not recognize the file and as a result, I have set it to inherit from the evo9base definition file. Opening the HEX file, I am now seeing that I have no access to any of the parameters
What do I need to do to fix this problem?
Cheers
Kenneth
Ryan - stock.hex
(512 KiB) Downloaded 680 times
ghoonk
Postby fbikawi » Sat Oct 20, 2007 2:39 pm
hi keneth,
i think the rom internal id for this car is 88580015 same as waleeds car.
the defention file is not available. i will look for it and if i found i will let you know
fbikawi
Postby ghoonk » Sat Oct 20, 2007 10:49 pm
It's okay, my tuner has already set up the definition files for this, as he tuned Ryan's car which is the same as Waleed's
Cheers
Kenneth
ghoonk
Postby fbikawi » Sun Oct 21, 2007 5:08 am
nice.
can you share the correct definition file of the 88580015 (i think last production patch of Evo IX RS) with us.
i managed to view main maps correctly using 88580014 bu i think still it needs to be fixed to see all maps correctly.
thanks for help
fbikawi
Postby lukasz4turbo » Fri Dec 14, 2007 12:30 am
I also need definition for 88580015...
Regards
lukasz4turbo
Postby SkyNight » Wed Dec 26, 2007 1:11 am
This definition is perfect for you:
http://forums.openecu.org/viewtopic.php?t=3057
SkyNight
