I sent my stock chip to someone who I now can't get in contact with, hence i can't buy a chip reader to get the ROM image and I was hoping someone on this forum may already have one available, or point me in the right direction?
I'm also chasing a definition file as I have no idea when it comes to this side of things. Once I've completed the remap I will be writing to an emulator using TunerPro RT (as I'm not sure what else I can use do perform this task)...the def files in this forum refer to file ext of XML while the TunerPro uses XDF...not sure if i can simply rename the file ext to get an XML to work as an XDF or if there is a fundamental difference between the 2?
Any pointers/info from other tuners here is much appreciated!! of course I'll continue to scour through the existing posts for more info too
Justin
