Page 1 of 2
EVO8 MN191022 JM9641 P300codefix
Mon Jan 30, 2006 5:34 pm
by cboles
another rom...
Mon May 15, 2006 7:08 am
by chrisw
So I am assuming these downloads are stock '03 ROMS with the p0300 fix?
There were several versions of the fix, do you know which rev these are?
[edit]
http://forums.openecu.org/viewtopic.php?t=546
saw this forum bug, but the question still remains, do you know the rev of this patch?
thanks
Thu May 18, 2006 4:26 am
by ScrappyJack
FWIW - I got the following error when trying to view this ROM: "The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again."
Sat May 20, 2006 4:50 pm
by chrisw
ScrappyJack wrote:FWIW - I got the following error when trying to view this ROM: "The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again."
I don't get that error when loading this ROM, I do get the error when downloading the ROM from the ECU.
Does anyone have a decent '03 ROM without the p0300 fix?
Mon May 22, 2006 7:47 am
by MalibuJack
I posted my stock first allocation rom on EvoM.. Forgot to post it here..
Immobilizer code has been changed to FFFF, change it to yours before you try to upload it.
Mon May 22, 2006 10:14 am
by c-spec
MalibuJack wrote:I posted my stock first allocation rom on EvoM.. Forgot to post it here..
hey this is vboy25 form evom, anyway does this come with the p0300 fixed??
also do you have the XML definition for this ? cause when i open it the rom axes are all wacky.
Mon May 22, 2006 6:29 pm
by chrisw
c-spec wrote:MalibuJack wrote:I posted my stock first allocation rom on EvoM.. Forgot to post it here..
No it does not. I loaded it yesterday, and the EVO is a whole different animal...
Mon May 22, 2006 8:46 pm
by c-spec
chrisw wrote:c-spec wrote:MalibuJack wrote:I posted my stock first allocation rom on EvoM.. Forgot to post it here..
you loaded into your ecu ?? what's your ecu ID ?? and what year is your evo?? and what doy ou mean by your evo is a whole different animal?
Sun Jul 09, 2006 12:52 pm
by justchil
I'm suprised no one has asked about comparing the roms to see what exactly the P0300 fix is. I just checked my map and its the same as Malibu (no P0300 fix) Case ID: MN132874 Internal ID: 94170008 which differs from the P0300 fix rom posted above.
I'm going to copy my settings over to this rom and see what happens.
Sun Jul 09, 2006 1:07 pm
by justchil
Interesting changes on the knock sensor filter map!
So far that's been the only thing I've noticed...
Sun Jul 09, 2006 2:42 pm
by RallyCam
Those 2 maps appear to be exactly the same, you just have the wrong offset for the top one, move it left one column and you have the same map as shown below.
Sun Jul 09, 2006 10:17 pm
by c-spec
RallyCam wrote:Those 2 maps appear to be exactly the same, you just have the wrong offset for the top one, move it left one column and you have the same map as shown below.
+1
Mon Jul 10, 2006 5:02 am
by justchil
^^ yeah
Any thoughts why this map wouldnt start in my car? I transfered my fuel/timing etc.. from my current map to this one... and yes I copied my immoblizer key over.
Mon Jul 10, 2006 5:52 am
by cboles
If you are transferring map data to a ROM that doesn't have correct map offset information you will be corrupting the ROM image and any number of things can go wrong.
Mon Jul 10, 2006 7:24 am
by MalibuJack
The definition associated with my 03 Rom (94170008) Knock Sensor Filter 1 Map is off by 12 bytes.. The definition itself needs to be updated for your next release.. The map is located at 485b not 4850
