EVO8 MN132874 JM9417
Postby cboles » Mon Jan 30, 2006 5:32 pm
an evo rom...
EVO8 MN132874 JM9417.zip
(117.35 KiB) Downloaded 831 times
Postby Nemis » Wed Feb 01, 2006 11:43 am
some info on how to get this? cable, programm etc?
Nemis
Postby cboles » Wed Feb 01, 2006 11:47 am
I'm using a different version of the OpenPort cable with an additional connector, new kernels for SH processors, and a new version of EcuFlash. It's not ready for release yet, but I thought people might enjoy perusing some files...
Postby radsdau » Thu Feb 09, 2006 5:59 pm
I'd be really interested in helping with this development. Can you palm any off in this direction? Alpha source etc?
Ta.
Postby cboles » Thu Feb 09, 2006 6:51 pm
The software has already been working well for a month now. I'm just working on some organizational issues with the XML metadata and the like so that the program is usable. I'm still resolving some hardware compatibilty issues between the EVO8 and EVO9 too. It looks like the new EVO OpenPort will be able to work with Subaru DBW ECUs too, but not WRX ECUs.
Postby radsdau » Fri Feb 10, 2006 3:40 pm
Good work Colby; looking forward to it.
Postby radsdau » Mon Feb 13, 2006 11:41 pm
Colby, I'm looking at the EVO8 MCU and trying to work out the bootloading. It appears that with ECU pin 79 tied high the MCU should go into boot mode out of reset; sending a bootloader to it should entirely erase all flash, according to the datasheet.
So what am I missing? This can't be right, else you'd not be able to dump the flash. Is it running in some other mode somehow, or is there a trick?
I'd be grateful if you could shed some light on this. Thanks.
Postby Evo4Mad » Mon Feb 20, 2006 3:56 pm
cboles wrote:I'm using a different version of the OpenPort cable with an additional connector, new kernels for SH processors, and a new version of EcuFlash. It's not ready for release yet, but I thought people might enjoy perusing some files...
That would be awesomely appreciated if you could post more details about the cable/kernel types/ and ecuflash source.
I have a lot of experience with coding c++ apps, and want to create some cool front end applications with graphs etc, for my Lancer Evolution as a hobby to share with everyone.
Postby AutoXer » Wed May 10, 2006 3:24 pm
Is this a stock rom?
AutoXer
Postby cboles » Wed May 10, 2006 4:08 pm
yes. i only post stock roms, unless otherwise noted.
Postby ob4 » Mon May 15, 2006 6:07 pm
I am a newbie to this ecu rom editing. I have the ecuflash installed and viewing rom data posted in this thread. I noticed that the hi and low oct maps are the same. Why is that?
ob4
Postby Matz » Mon May 15, 2006 9:26 pm
ob4 wrote:I am a newbie to this ecu rom editing. I have the ecuflash installed and viewing rom data posted in this thread. I noticed that the hi and low oct maps are the same. Why is that?
Yeah, I was just IM'ing with earlyapex about that. Only the upper left cell of 9417 is different between the two maps. I was confused as well.
Matz
Postby vtluu » Mon May 15, 2006 10:17 pm
Compare with EVO8 JM9693, an '05 ECU map. Markedly different high and low-octane maps.
vtluu
Postby Hitokiri » Tue May 16, 2006 9:22 am
this rom has some really wierd data in it. It seems to be much more agressive fuel and timing wise than the newer images.
any idea if this rom is really stock??
and the high det / low det issue mentioned above?
Postby DarkECU » Fri May 19, 2006 2:09 pm
<ecu_struct id="9417-08" type="JM9417-08 -> MN 132874 EVO 8 USA MY03" include="">
<map name="33BD -> Fuel Map High Octane" type="3" active="1" help="" >
<cols count="18" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6440" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6418" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#33BD" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="34D7 -> Fuel Map Low Octane" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#34D7" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="39D5 -> Ignition Map High Octane" type="3" active="1" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<cols count="19" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#64A0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#646E" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#39D5" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3B5D -> Ignition Map Low Octane" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3B5D" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<cols count="19" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="19" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="Engine Rev Limit" >
</map>
<map name="0 -> Fuel Map High Octane" type="3" active="0" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#0" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #1" type="3" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane #1" type="3" active="0" help="Maximum asynchronous injection pulse width." >
</map>
<map name="0 -> Ignition Map High Octane #1" type="3" active="0" help="Asynchronous injection compensation used briefly after engine startup." >
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane #1" type="3" active="0" help="" >
</map>
<map name="0 -> VVT (Variable Valve Timing) Map" type="3" active="0" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map High Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #2" type="3" active="0" help="" >
</map>
</map>
</map>
<map name="0 -> Ignition Map High Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #3" type="3" active="0" help="" >
</map>
</map>
</map>
<map name="0 -> Ignition Map High Octane #4" type="3" active="0" help="" >
</map>
</map>
<map name="0 -> Belch Map" type="3" active="0" help="" >
<cols count="5" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Cough Map 1" type="3" active="0" help="" >
<cols count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="24" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Squit Map" type="3" active="0" help="" >
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="30" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Flob Map" type="3" active="0" help="" >
<rows count="28" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Cough Map 2" type="3" active="0" help="" >
</map>
<map name="0 -> Splutter Map" type="3" active="0" help="" >
<cols count="26" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Wheeze Map" type="3" active="0" help="" >
<cols count="25" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="35FC -> TFCNEH3_MA" type="3" active="1" help="" >
<cols count="3" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#35FC" power="1" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3FF5 -> Advance DWRT (19*20)" type="3" active="1" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3FF5" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*19)" type="3" active="0" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (21*19) #1" type="3" active="0" help="Maximum integral value." >
</map>
<map name="0 -> Advance DWRT (21*19) #1" type="3" active="0" help="" >
</map>
<map name="0 -> Advance DWRT (21*19) #2" type="3" active="0" help="" >
</map>
</map>
<map name="0 -> Advance DWRT (21*19) #3" type="3" active="0" help="" >
</map>
</map>
<map name="0 -> TFLICS" type="3" active="0" help="" >
<cols count="27" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Steps (Steps)" desc="Steps (Steps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TIEL" type="3" active="0" help="" >
<cols count="11" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Current (Amps)" desc="Current (Amps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TBMTHWVA1" type="3" active="0" help="" >
<cols count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> TBMTHA2" type="3" active="0" help="" >
</map>
</map>
<map name="3614 -> Boost Limit" type="2" active="1" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B7E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3614" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="44A0 -> Max Wastegate Duty - A" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#672E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#44a0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="44B6 -> Max Wastegate Duty - B" type="2" active="1" help="" >
<data offset="#44b6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="44CC -> Max Wastegate Duty - C" type="2" active="1" help="" >
<data offset="#44cc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="44E2 -> Max Wastegate Duty - D" type="2" active="1" help="" >
<data offset="#44e2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="44F8 -> Boost Desired Engine Load - A" type="2" active="1" help="" >
<data offset="#44f8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="450E -> Boost Desired Engine Load - B" type="2" active="1" help="" >
<data offset="#450e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4524 -> Boost Desired Engine Load - C" type="2" active="1" help="" >
<data offset="#4524" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="453A -> Boost Desired Engine Load - D" type="2" active="1" help="" >
<data offset="#453a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="5A64 -> AFM" type="2" active="1" help="" >
<rows count="116506" format="" func_2val="" func_val2="ngine load to be achieved by regulation of turbo boost pressure. Add 1D value 'Boost Control - Desired Engine Load Offset' to determine desired load. 200% load is approx 1.2bar of boost." offset="#3351" power="2" caption="" desc=" ()" signed="False" reverse_bytes="False"/>
<data offset="#5a64" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - E" type="2" active="0" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - F" type="2" active="0" help="" >
</map>
<map name="0 -> Max Wastegate Duty - G" type="2" active="0" help="" >
</map>
<map name="0 -> Boost Desired Engine Load - E" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3864 -> Acceleration Enrichment" type="2" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#61B2" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3864" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4488 -> Turbo Dynamics" type="2" active="1" help="" >
<rows count="17" format="%.1f" func_2val="[value]/8192" func_val2="[value]*8192" offset="#6758" power="2" caption="%" desc="Boost Error (%)" signed="False" reverse_bytes="True"/>
<data offset="#4488" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Turbo Dynamics (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3624 -> Open Loop Load #1" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6124" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3624" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="363A -> Open Loop Load #2" type="2" active="1" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
<data offset="#363a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3656 -> Open Loop Throttle Low Load" type="2" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<data offset="#3656" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="366C -> Open Loop Throttle High Load" type="2" active="1" help="" >
<data offset="#366c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="37C0 -> Injector battery voltage compensation" type="2" active="1" help="Maximum asynchronous injection pulse width." >
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6380" power="2" caption="V" desc="Battery Voltage (V)" signed="False" reverse_bytes="False"/>
<data offset="#37c0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="ms" color_dir="0" desc="Lag Time (ms)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="425A -> Desired Idle RPM - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6630" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#425a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4268 -> Desired Idle RPM - Drive" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6616" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#4268" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4276 -> Desired ISCV initial step position with AC off - Neutral" type="2" active="1" help="" >
<data offset="#4276" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4284 -> Desired ISCV initial step position with AC off - Drive" type="2" active="1" help="" >
<data offset="#4284" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4292 -> Desired ISCV initial step position with AC on - Neutral" type="2" active="1" help="" >
<data offset="#4292" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="42A0 -> Desired ISCV initial step position with AC on - Drive" type="2" active="1" help="" >
<data offset="#42a0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3306 -> AFM speed ?" type="2" active="1" help="" >
<rows count="21" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6330" power="2" caption="Hz" desc="Frequency (Hz)" signed="False" reverse_bytes="False"/>
<data offset="#3306" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3322 -> AFM Frequency compensation" type="2" active="1" help="" >
<data offset="#3322" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33A2 -> AFM Air Temperature compensation" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#664A" power="2" caption="C " desc="Air Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#33a2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="337C -> AFM Pulses Per Second ?" type="2" active="1" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#337c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="pps" color_dir="0" desc="Pulses per second (pps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3394 -> AFM Water Temperature compensation" type="2" active="1" help="Engine Rev Limit" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#654E" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3394" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="35F4 -> Overrun Fuel Cut-off RPM vs Coolant Temp" type="2" active="1" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data offset="#35f4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="37C7 -> Inj. Time Compensation" type="2" active="1" help="Maximum integral value." >
<rows count="36" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#37c7" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="usec" color_dir="0" desc="Fuel Inj Time Comp (usec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="387A -> A/F Correction Coeff for water temp" type="2" active="1" help="" >
<data offset="#387a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Percent (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38A2 -> Asynchronous Injection base pulse width against throttle angle delta" type="2" active="1" help="" >
<rows count="10" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6106" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#38a2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38B2 -> Asynchronous Injection limitation TPS voltage" type="2" active="1" help="" >
<data offset="#38b2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38C2 -> Asynchronous Injection coolant temp compensation coefficient" type="2" active="1" help="" >
<data offset="#38c2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38D0 -> Asynchronous Injection compensation coefficient against Ne" type="2" active="1" help="" >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#38d0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="397A -> Lean Spool: Trailing time (rich side)" type="2" active="1" help="" >
<rows count="14" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#63DA" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#397a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="398E -> Lean Spool: Trailing time (lean side)" type="2" active="1" help="" >
<data offset="#398e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="39A2 -> Lean Spool: Engine Load Threshold" type="2" active="1" help="" >
<data offset="#39a2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="39B6 -> Lean Spool: AFR Adjustment" type="2" active="1" help="" >
<rows count="7" format="%.1f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] / 128)" offset="#6400" power="2" caption="AFR" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True"/>
<data offset="#39b6" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" power="1" caption="AFR" color_dir="0" desc="Fuel Map Val (AFR)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="421A -> Knock control judgement boost map" type="2" active="1" help="" >
<rows count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#421a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="422A -> Knock learning function area boost map" type="2" active="1" help="" >
<data offset="#422a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="424C -> Knock learning function initialise value" type="2" active="1" help="" >
<data offset="#424c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="51FC -> Air Inject Time" type="2" active="1" help="Engine load value that must be added to desired engine load 2D maps to determine actual desired boost profile." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B62" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#51fc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="msec" color_dir="0" desc="Air Inject Time (msec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> ?????????" type="2" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi Off Fan Control" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="km/h" color_dir="0" desc="Vehicle Speed (km/h)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi On Fan Control" type="2" active="0" help="" >
</map>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="degree" color_dir="0" desc="Temperature (degree)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
<map name="42AE -> ISC Steps" type="2" active="1" help="" >
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#42ae" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="42BC -> ISC D/P initial from Throttle Voltage AC Off - Neutral" type="2" active="1" help="" >
<rows count="7" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#42bc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="42CA -> ISC D/P initial from Throttle Voltage AC Off - Drive" type="2" active="1" help="" >
<data offset="#42ca" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="42D8 -> ISC D/P initial from Throttle Voltage AC On - Neutral" type="2" active="1" help="" >
<data offset="#42d8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="42E6 -> ISC D/P initial from Throttle Voltage AC On - Drive" type="2" active="1" help="" >
<data offset="#42e6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4338 -> ISC desired position high altitude compensation" type="2" active="1" help="" >
<rows count="5" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4338" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="434A -> ISC Error Dynamics - Neutral" type="2" active="1" help="" >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False
DarkECU
