Help to connect to USDM IXMR
I am having trouble connecting to a IX MR. I know it has been flashed before, but had no luck even with ECU Unlocker. It has to be someting simple that I am doing wrong.
Openport 1.3M installed correctly and is showing in the lower right of Ecuflash 1.30.
When I try to read from the ecu and select 2006 Evo9, all I get is "unable to connect to vehicle interface." The key should be two clicks in the acc on position right?
I thought maybe the cable was not installed right, but evoscan logs fine and checks codes fine.
