How do my flashes look
Postby idriveaevo9 » Fri May 18, 2007 12:32 pm
OK im putting a flash on but i dont know which one to choose but before i install it i wanted to know if i will need to put a bigger pump in i have 2 maps which one is the better i dont mind having to do mods if needed to make them work just will they run good and strong
keep in mind this were not my full tunes im still learning the software
file 2.bin
(512 KiB) Downloaded 493 times
file 1.hex
(512 KiB) Downloaded 467 times
idriveaevo9
Postby oldevodude » Sat May 19, 2007 10:31 am
I guess it might be helpfult to know where you got the maps?
What are your intentions for your car?
I thik you might be going about it backwards.
You should have a plan for your car
You should execute plan and then have maps made for your car when you feel you might be done.
oldevodude
