3 High & Low octane maps, which one to tune???
Postby got boost? » Sat Apr 28, 2007 9:59 pm
Hi, i noticed that in the EVO IX ROM there's 3 hi n low octane ignition maps, on monday i'll begin with the tune and i have some doubts.
I know that at normal condition, the high octane map is working and that under knock, the low octane map works, but WICH ONE OF THE 3 HIGH AND LOW MAPS DO I HAVE TO TUNE???
Thanks a lot guys.
got boost?
Postby got boost? » Wed May 02, 2007 7:58 pm
anyone????
got boost?
Postby Newfoundlancer » Wed May 02, 2007 11:10 pm
You may wanna check out the ECUFlash subforums on EvolutionM.net within the Evo Engine Management/Tuning section. They have the Evo's tuning covered pretty well over that way.
Newfoundlancer
Postby fastevo » Wed May 09, 2007 2:02 pm
the 2nd one. 1st is for cold start, 3rd is an "emergency mode" operation. don't take my word for it, go to forums.evolutionm.net and do a search.
fastevo
Postby oldevodude » Sat May 19, 2007 10:36 am
If you run logging software you can log load and timing along with modifying your map for 2-byte load. when you log you will see exactly which map you are running off of. If you compare your logged data to the tables you can see exactly wich map you are running from.
Evolutionm.net is a great resource and lots of reading info. to learn from
oldevodude
