Empty field in the Injector Scaling
Postby joedr » Wed Feb 07, 2007 3:56 pm
All,
I can edit all of the fields in this rom with the exception of the Injector Scaling as you can see in the attached picture.
I also attached the rom (rev 13). Do I need a modified definition? Any help will be greatly appreciated?
Thanks!
-J
IX MR.hex
IX MR Rev 13
Inj Scaling missing
(512 KiB) Downloaded 717 times
joedr
Postby burgers » Mon Feb 12, 2007 9:50 pm
Hi
I had a similar thing happen when I first started using my widescreen laptop. You could try messinge with the DPI settings for your display, another fix I found was to go into the map editor, the scalings section and change the format from 0f to 1f.
MB
burgers
