Can RALLIART ECU be written to OEM
Postby rileyrally » Fri Feb 02, 2007 2:23 am
I am just wonder what the difference is between the following
RALLIART ECU
OEM ECO and
FQ ECU
IS it just the maps?
or
Is it the actually ECU(Hardware) itself
Can RALLIART MAPS be written to a OEM ECU eg. AUSDM ECU
or FQ maps be written to OEM
rileyrally
Postby malinen » Fri Feb 02, 2007 3:35 am
I think the hardware is the same? Only difference is the maps.. correct me if i'm wrong :)
malinen
Postby nvr2fast » Tue Feb 06, 2007 6:45 pm
You can flash Ralliart and FQ into stock ROM. Make sure you update the immobilizer code.
nvr2fast
Postby Sanctifier » Sun Feb 11, 2007 11:45 pm
nvr2fast wrote:You can flash Ralliart and FQ into stock ROM. Make sure you update the immobilizer code.
Are there any detailed instructions anywhere for updating the immobilizer code safely?
Sanctifier
Postby S54fan » Mon Feb 12, 2007 2:52 pm
Be very careful. IX FQ has dual boost solenoids and 3 bar MAP sensor and is based on JDM. I don't know what would happen if you flash this to EDM or USDM.
Even flashing a JDM GSR image onto a JDM GT wouldn't start the car yet the actual maps inside the ROM are identical.
I tend to advise people to consider hints or even copying maps across but into their original ECU.
I don't know about Ralliart ECUs though, but I think there would need to be versions for the different markets given the hardware differences between the cars.
Postby MalibuJack » Sat Feb 24, 2007 6:44 am
You'd be surprised.. Many of the ECU's are identical for all of the models, but the wiring from the car to the ECU varies, which is why roms are unique to specific models.
This bit of information isn't really all that useful or surprising, BUT it means that you have to be real careful about swapping roms around. There are some that might work, but due to the trial and error, and the possibility you can do harm, has limited how much experimenting with rom interchange there is between different cars.
As stated above, if sensors or inputs are different between two models your looking at, then you can be sure the roms will not be compatible (either it won't run, sensors won't work right, or you can damage something)
a good example is the 2003-2004 USDM Evo, there's a good chance that any rom from those two years can be used on any other 2003/2004.. But a 2005 has slightly different wiring (No Intercooler sprayer for example) and some other changes, and a 2003 rom on a 2005 may not work properly. (I'm actually not sure if anyone has actually tried this extensively)
But to point out, the 3rd gen ECU's (2001-2005) are for the most part physically the same, different generations have slightly different hardware internally, but you can find a rom that will be compatible with your car and it should work as long as you didn't lose your immobilizer.
MalibuJack
