Fuel map autoadaptive evo9
Hello there
I found a strange fenomena after fuel map data change, so after change for test some line centered for load and rpm ie 10 or 16 afr, I noticed the ecm come back to teorically afr after a few seconds, verified with evoscan and afr meter
I can imagine that related to open loop or close loop but in any case after any re-writing in map data rules should be new
Did you checked this issue before ?
thanks
thanks
