ROM - 88580014 EVO 9, EDM, Manual, SH7055
Postby tango » Fri Dec 01, 2006 5:51 pm
would anyone know or have the XML file of this evo9 EDM 88580014? thanks guys
tango
Sorry
Postby mtcavity » Fri Dec 01, 2006 10:30 pm
I had this one but never applied it to the uploads, sorry about the delay.
05_LANCER_EVO9_EDM_88580014 - XML - ROM.rar
(114.68 KiB) Downloaded 546 times
mtcavity
Postby tango » Sat Dec 02, 2006 12:37 am
why not? what happened?
tango
Postby ralliart » Sat Dec 02, 2006 1:01 am
Why you don't use this : http://forums.openecu.org/viewtopic.php?t=1301
Match perfectly with IX euro :D
ralliart
Postby tango » Sat Dec 02, 2006 2:05 am
just to confirm i will use those files, including the stock file as a base, then after altering the parameters i will up load that?
tango
What happened.
Postby mtcavity » Sat Dec 02, 2006 9:32 pm
I did not post because ralliart had original post. I found Boost Enhancement Maps (ignition and fuel) and have the maps posted in the version above, which is the only difference between XMLs.
Other than that the XML is originally ralliart's, while I just added to it.
mtcavity
Postby aalzuhair » Mon Jun 04, 2007 2:11 am
I worked on this file for some time now. It works well but some of the fileds are still wrong and needs to be worked on (i.e. MAP, ASL, MUT, ECU Periphery). I'm trying to make it perfect :)
Thank you for your input,
Az
88550014 and MAP.zip
(130.26 KiB) Downloaded 410 times
aalzuhair
Postby Settdimisti » Tue Jul 03, 2007 11:33 pm
can you guys see the stationary rev limit properly with these hex files? i dont think i get the right values
Settdimisti
Postby SkyNight » Sun Aug 05, 2007 1:35 pm
Settdimisti wrote:can you guys see the stationary rev limit properly with these hex files? i dont think i get the right values
Both are perfect...
SkyNight
Postby SkyNight » Sat Aug 11, 2007 5:15 am
MAF Scaling
Change scaling to AirFlow8
SkyNight
