read but can't see
read but can't see
Postby tuning g » Sat Oct 07, 2006 4:04 pm
Can you guys see if you have a xml file for this map please it is for a 2005 lancer evolution 9
I know it is a IX but the year is questionable
dantheoc.hex
(512 KiB) Downloaded 642 times
tuning g
Postby S54fan » Sun Oct 08, 2006 1:28 am
Inherit 88570008.xml
Dual solenoid, GSR-like map. Fuel cut is max. VVT is tame. Lean spool enable is 3500 RPM - worth changing to 2500 to stop it running lean especially when you increase the boost a lot in this area.
Postby tuning g » Sun Oct 08, 2006 5:43 am
Ever had any problems where when you back off the throttle while driving in third or forth the car stays at 3750rpm for about 3-4 sec then comes down to idle never happened before the reflash car also has a fuel pump
tuning g
Postby S54fan » Sun Oct 08, 2006 7:53 am
No, but they go on about it on evolutionm.net if you look there.
Postby tuning g » Sun Oct 08, 2006 8:56 am
thanks for the reply
tuning g
