What do you think of this VVT map?
Postby fredd^ » Sun Sep 17, 2006 11:13 am
Can anyone compare my VVT map to the RS JDM model and say what map is best for high RPM performance or witch is best overall.
Is it worth trying the RS map instead of mine?
/Fredd
Mod_Euro_EVO9.bin
(512 KiB) Downloaded 904 times
fredd^
Postby nvr2fast » Sun Oct 22, 2006 7:07 pm
The RS map I suspect is really good for the IX RS turbo, which is magnesium and spools quicker.
Or perhaps someone who has tried the RS MIVEC map on a regular IX turbo can comment?
nvr2fast
Postby evo400 » Mon Oct 23, 2006 5:00 am
I am using the JDM maps as my starting point includint this VVT map and the overall response is pretty good!
evo400
Postby malinen » Thu Nov 02, 2006 2:03 am
evo400 wrote:I am using the JDM maps as my starting point includint this VVT map and the overall response is pretty good!
Do you use this VVT map also as a starting point for GSR's with normal non-magnesium turbos ?
malinen
Postby evo400 » Thu Nov 02, 2006 4:12 am
Yes, i have the GSR, and the JDM GT ecu bin works well with it.
evo400
Postby Keiran » Thu Nov 09, 2006 7:54 pm
GSR and JDM GT has the same codes .. only the RS is different ..
Yes, you can gain a slightly quicker spoolup using the RS VVT .. and some guys actually modify the VVT to make it better all round using the RS as a base ..
Keiran
Postby west_minist » Sun Nov 12, 2006 8:15 pm
Slightly off topic, but when I look in the EVO Boost maps, it is way different to Subaru;s and other EMS.
I have not spent a lot of time on this topic, but if you can point out a reference, I would greatly appreciate it.
Postby bruno » Wed Nov 22, 2006 4:27 am
can someone inlight me on how the VVT map works ?
let's say I want more in high rpm , what can I do , how do I change the map ?
regards
Bruno
bruno
Postby Tuned by LIM » Wed Nov 22, 2006 11:55 am
Tuned by LIM
Postby bruno » Thu Nov 23, 2006 12:10 am
thanks for the link :wink:
bruno
Postby myvekdrifters » Tue Jan 09, 2007 11:19 pm
will this work on the US Spec mivec map?
myvekdrifters
Postby Wayne_Coots » Fri Feb 16, 2007 3:07 pm
yes!
Wayne_Coots
