can someone give me this map "description?"
Sat Sep 16, 2006 2:49 pm
by Dapper_Dan
here it is
Mon Sep 18, 2006 11:12 am
by burgers
Hi
Please help us help you by posting:-
1. Model and arae of car (ie Evo VII JDM)
2. Year
3. ECU box code.
This willl make identiffying to correct deffinition file much easier.
MB
Mon Sep 18, 2006 3:50 pm
by radsdau
EVO8, JM9417-15. Should be case code MN132874. USDM.
Confirm?
XML
Mon Sep 18, 2006 6:48 pm
by mtcavity
I renamed the ROM for quicker ID.
Shared almost the same map as 94170014 (should be a like model and year), although the Wastegate Compensation is not defined. The only differance between the two is the load and table addresses for the Boost Limit.
If you find out any more info on the ROM, let me know so I can update the XML discription for accuracy.
