can someone give me this map "description?"
Postby Dapper_Dan » Sat Sep 16, 2006 2:49 pm
here it is
chris' ecu.hex
(256 KiB) Downloaded 681 times
Dapper_Dan
Postby burgers » Mon Sep 18, 2006 11:12 am
Hi
Please help us help you by posting:-
1. Model and arae of car (ie Evo VII JDM)
2. Year
3. ECU box code.
This willl make identiffying to correct deffinition file much easier.
MB
burgers
Postby radsdau » Mon Sep 18, 2006 3:50 pm
EVO8, JM9417-15. Should be case code MN132874. USDM.
Confirm?
XML
Postby mtcavity » Mon Sep 18, 2006 6:48 pm
I renamed the ROM for quicker ID.
Shared almost the same map as 94170014 (should be a like model and year), although the Wastegate Compensation is not defined. The only differance between the two is the load and table addresses for the Boost Limit.
If you find out any more info on the ROM, let me know so I can update the XML discription for accuracy.
2004 Mitsubishi Lancer EVO 8 USDM (MT) [94170015] - ROM - XML.rar
(107.56 KiB) Downloaded 438 times
mtcavity
