just a thought for putting an 8 ecu into an earlier evo is to rejumper the ecu rather than cutting the loom.
The jumpers are on the bottom of the pcb at the top left.
j10 to j11
j12 to j13
you need a fine soldering iron and tweezers but the result is you can then swap back and forth between the ecus and the authorities don't see any wiring changes.
Also you can't get confused about wiring pin numbers as the jumpers are un-ambiguous.
