VI TME ECU
Re: VI TME ECU
Postby mistamidget » Thu May 20, 2010 9:18 pm
excellent news thanks guys
I would appreciate an unmodded original TME .hex evotme. Do you want me to PM you my email or can you post it in the thread?
I'll try flashing that with the 8 setting and see how that goes.
Cheers.
mistamidget
Re: VI TME ECU
Postby evotme » Fri Jun 04, 2010 7:06 am
pls pm with your email address...
evotme
Re: VI TME ECU
Postby mistamidget » Fri Jun 25, 2010 6:07 am
FYI, got the ECU reflashed and running using the following .xml file for the 128K 27370001 image.
thanks to all those who have helped out with this problem.
27370001.xml
(16.49 KiB) Downloaded 842 times
mistamidget
Re: VI TME ECU
Postby earlyapex » Sat Oct 02, 2010 12:51 pm
Hey guys,
There is a Evo 6.5 TME I've been trying to tune but I can't seem to even be able to pull the rom from it.
I'm using the latest beta of Ecuflash 1.43.3150
Using openport 2.0 with latest drivers with the secondary cable plugged into the white underdash connector
I select "2nd Gen/Evo6.5 MH7203F" frim the menu and try to read the ecu and it errors out:
[13:48:29.540] J2534 API Version: 04.04
[13:48:29.540] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[13:48:29.540] Device Firmware Version: 1.11.3137
[13:48:29.540] Device Serial Number: TAW7Z099
[13:48:31.961] sending init sequence 2
[13:48:33.966] interface close
What are we doing wrong?
- Bryan
earlyapex
