Need Help on this e9 ROM
Postby Mellon » Fri Feb 15, 2008 6:57 am
they guy that needs help with his evo said he is able to view the rom properly. I tried the 89980000 definition file he supplied to me and it seems to be the same one I've found here. Same problem with application crashing.
However, he also sent me his entire evo definition folder from his ecuflash install. I unzipped and overwrote my 1.34 evo folder and sure enough it works now.
I'll attach both.
89980000.xml
(12.97 KiB) Downloaded 443 times
evo.zip
(74.88 KiB) Downloaded 286 times
Mellon
Postby R. Mutt » Sun Feb 17, 2008 7:05 am
Mellon wrote:they guy that needs help with his evo said he is able to view the rom properly. I tried the 89980000 definition file he supplied to me and it seems to be the same one I've found here. Same problem with application crashing.
I'll attach both.
Only now seeing the request else I would have uploaded my defs. :lol: ...those are my definitions you attached. I think the reason it didn't work was because you needed the same evo9base.xml definition file we were running. The 89980000 basically included the evo9base.
R. Mutt
