EVO8 MN191022 JM9641 P300codefix
Postby cboles » Mon Jan 30, 2006 5:34 pm
another rom...
EVO8 MN191022 JM9641 P300codefix.zip
(122.87 KiB) Downloaded 756 times
Postby chrisw » Mon May 15, 2006 7:08 am
So I am assuming these downloads are stock '03 ROMS with the p0300 fix?
There were several versions of the fix, do you know which rev these are?
[edit]
http://forums.openecu.org/viewtopic.php?t=546
saw this forum bug, but the question still remains, do you know the rev of this patch?
thanks
chrisw
Postby ScrappyJack » Thu May 18, 2006 4:26 am
FWIW - I got the following error when trying to view this ROM: "The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again."
ScrappyJack
Postby chrisw » Sat May 20, 2006 4:50 pm
ScrappyJack wrote:FWIW - I got the following error when trying to view this ROM: "The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again."
I don't get that error when loading this ROM, I do get the error when downloading the ROM from the ECU.
Does anyone have a decent '03 ROM without the p0300 fix?
chrisw
Postby MalibuJack » Mon May 22, 2006 7:47 am
I posted my stock first allocation rom on EvoM.. Forgot to post it here..
Immobilizer code has been changed to FFFF, change it to yours before you try to upload it.
03Evo-Stock.zip
(117.72 KiB) Downloaded 559 times
MalibuJack
Postby c-spec » Mon May 22, 2006 10:14 am
MalibuJack wrote:I posted my stock first allocation rom on EvoM.. Forgot to post it here..
hey this is vboy25 form evom, anyway does this come with the p0300 fixed??
also do you have the XML definition for this ? cause when i open it the rom axes are all wacky.
c-spec
Postby chrisw » Mon May 22, 2006 6:29 pm
No it does not. I loaded it yesterday, and the EVO is a whole different animal...
chrisw
Postby c-spec » Mon May 22, 2006 8:46 pm
you loaded into your ecu ?? what's your ecu ID ?? and what year is your evo?? and what doy ou mean by your evo is a whole different animal?
c-spec
Postby justchil » Sun Jul 09, 2006 12:52 pm
I'm suprised no one has asked about comparing the roms to see what exactly the P0300 fix is. I just checked my map and its the same as Malibu (no P0300 fix) Case ID: MN132874 Internal ID: 94170008 which differs from the P0300 fix rom posted above.
I'm going to copy my settings over to this rom and see what happens.
justchil
Postby justchil » Sun Jul 09, 2006 1:07 pm
Interesting changes on the knock sensor filter map!
So far that's been the only thing I've noticed...
justchil
Postby RallyCam » Sun Jul 09, 2006 2:42 pm
Those 2 maps appear to be exactly the same, you just have the wrong offset for the top one, move it left one column and you have the same map as shown below.
RallyCam
Postby c-spec » Sun Jul 09, 2006 10:17 pm
RallyCam wrote:Those 2 maps appear to be exactly the same, you just have the wrong offset for the top one, move it left one column and you have the same map as shown below.
+1
c-spec
Postby justchil » Mon Jul 10, 2006 5:02 am
^^ yeah
Any thoughts why this map wouldnt start in my car? I transfered my fuel/timing etc.. from my current map to this one... and yes I copied my immoblizer key over.
justchil
Postby cboles » Mon Jul 10, 2006 5:52 am
If you are transferring map data to a ROM that doesn't have correct map offset information you will be corrupting the ROM image and any number of things can go wrong.
Postby MalibuJack » Mon Jul 10, 2006 7:24 am
The definition associated with my 03 Rom (94170008) Knock Sensor Filter 1 Map is off by 12 bytes.. The definition itself needs to be updated for your next release.. The map is located at 485b not 4850
MalibuJack
