evo5 xml question
evo5 xml question
Postby ykchong4 » Sat Dec 03, 2011 8:57 am
can somebody explain why this evo5 xml can read as normal in ecuflash, but when i need to convert to ecuedit or other program found that every address inside the rom need minus 10000(hex).
for example in ecuflash table for high octane ignition data value start from 11def, if i put inside the ecuedit hex editor found that the correct address is 01def not 11def? thanks for help
evo5-jdm-stock.hex
(128 KiB) Downloaded 800 times
evo5base.xml
(22.4 KiB) Downloaded 800 times
22580007.xml
(14.03 KiB) Downloaded 780 times
ykchong4
Re: evo5 xml question
Postby ykchong4 » Tue Dec 06, 2011 9:41 pm
bring up my post...
ykchong4
