EVO X Euro Version
EVO X Euro Version
Postby ronisc » Wed Feb 11, 2009 1:42 pm
Hi everybody,
Please can some body help for a xml file for attached evoX 2008 euro MT Stock files?
It will be very sweet, when i can get one.
Thanks at advanced
Roni
read image_evox_ad_blau.hex
(1 MiB) Downloaded 1145 times
ronisc
Re: EVO X Euro Version
Postby acamus » Wed Feb 11, 2009 10:02 pm
Here is one to start with, there are few bytes offsets on main maps, so if you play with it you can get it correct.
53040008.xml
(468 Bytes) Downloaded 1200 times
acamus
Postby ronisc » Thu Feb 12, 2009 6:08 am
Hi,
Thanks alot i will do it.
Have a nice time
BR
Roni
ronisc
Postby hkaevox » Thu Feb 12, 2009 2:40 pm
hi,
there are some problems of the xml file
for example injector battery voltage's.
hkaevox
Postby acamus » Thu Feb 12, 2009 11:19 pm
Maybe you overlooked "one to start with"
acamus
Postby AIK » Sat Feb 14, 2009 4:37 am
Has tried to make a file, to flash it yet did not try.
53040007.xml
(12.7 KiB) Downloaded 964 times
AIK
Postby AIK » Mon Feb 16, 2009 10:32 am
New release))) with correct limits tables
53040007.xml
(12.7 KiB) Downloaded 901 times
AIK
Postby AIK » Mon Feb 16, 2009 1:06 pm
and new again
throttle(%) in boost target correct now too
53040007.xml
(12.7 KiB) Downloaded 1208 times
AIK
Postby blackvr » Wed Feb 18, 2009 1:54 am
Thanks for the XML AIK. It works great with my Aus Spec rom ( the same as a EDM rom).
Cheers Mike
blackvr
Postby AIK » Wed Feb 18, 2009 12:11 pm
I am glad help when i can do it.
AIK
Postby ronisc » Thu Feb 19, 2009 5:45 am
Hi Aik,
Thx alot for your help.
Best wish
Roni
ronisc
Postby ronisc » Wed Feb 25, 2009 12:03 am
Hi,
Need again help please. It will be very sweet.
I have a stock file from Evo X SST / EUR Version
Can sombody help me with a romdeffinition, please.
Regards
Roni
read_image_evox_sst_schwarz_carlone1_1860A982_ECU_SW_part number _1860A98203_VIN_JMBSMCZ4A9U001266.hex
(1 MiB) Downloaded 1066 times
ronisc
Postby defx2 » Mon Apr 20, 2009 12:44 am
I'm Searching for the 53040009.xml (Edm EvoX Mr).
Have someone the XMl for this Car?
defx2
Postby spyder » Fri Aug 14, 2009 11:44 pm
Try this 2!
53050009.xml
(11.33 KiB) Downloaded 1048 times
53040009.xml
(11.33 KiB) Downloaded 1002 times
spyder
