I want to use ecuflash to edit ROM's for my 1g DSM. I was wondering how I begin making a custom definition for my from. I know most of the addresses of my maps, I just don't know how to get started.
thanks,
dan
radsdau wrote:The best advice I can give is to follow by example. Most of it can be worked out by looking at the XML files supplied with ECUFlash or ROMRaider.
You won't be using ECUFlash for the reflashing, only the ROM editing. You can write your own definitions to tune ANY ROM type, so long as you work out where the maps are and what format they're in, etc. It doesn't matter what micro or memory model the ROM uses.
Gatecrasher wrote:I dunno about that. As xor said, EcuFlash doesn't support the MH61xx MCU.
EcuFlash requires you to be able to specify the location of the map, AND the location of the axes in the ROM.
The DSMs don't have the axes stored in the ROM. They're calculated and/or implied. They're not explicitly stated like other Mitsu models...
