Anti-Lag / Launch Control
Postby cossie1 » Thu Dec 20, 2007 4:55 pm
Ok guys, as some of you know, I have an Evo 6 RS2, which is running an Evo 7 Ecu, with a Ralliart rom on it, that i've tweaked to suit my car.
I've read that Anti-lag and Launch control can be implemented on an Evo 5/6 using that expensive sw that tuners seem to rave on about.
But........
Can it be done using ecu flash on the evo 7 ecu running in an evo 6 ???
If so, How do I go about getting it working ?
I know that it can't be switched off, but I just fancy having a play about, and I can easily switch between maps when I fancy a play, and when I need to be sensible.
So any help would be great.
Cheers
cossie1
