EVO IX GT JDM 89280002
Postby Tuned by LIM » Fri Aug 25, 2006 12:42 am
some maps like knock sensor filter, boost, idle was wrong. :(
you need to find the right address by yourself. :?
but no problem with main map like fuel and ignition map. :)
Tuned by LIM
Postby tuning g » Fri Aug 25, 2006 2:12 am
all maps look scrambled fuel and timing also the mivec maps
tuning g
Postby S54fan » Fri Aug 25, 2006 2:59 am
Boost, MIVEC, fuel, ignition etc should be OK if you are using my 8857-08 xml. The knock sensor filter and idle stuff was just copied from the JM8859 - I had no reason to actually find these items, if you want to find them and modify the xml be my guest, post the updated XML here.
Postby S54fan » Sat Aug 26, 2006 2:57 am
I can't find knock sensor filters on the 8857-08 in the format they are in on the US models. Maybe it is done differently.
Postby Zakie@TIC » Mon Aug 13, 2007 2:04 am
Hi, I'm a newbie from Sri Lanka, Can I have some help for a 34mm restricter program to run higher boost than stock with as much top end cos of a long straight.
The Car is a early 2006 JDM EVO9 with 89280002 internal ID.
PS: Is the full XML out for the 89280002
Zakie@TIC
