have some guys of you some problems with the P0505 code?
it is for the idle stabilisation.
please post if you have it.
a interesting thing would be the setup of the car
thanks.
Rotawerx wrote:flash, do you have this code, or are you just curious. If so, why...?
salex wrote:Try cleaning your throttle valve. It gets oily and everythings starts going wrong then... You probably won't see the trouble code again for some time once you've done that.
flash wrote:big exhaust, testpipe, open intake, changed cams
