MAP sensor scaling hunt
PostPosted: Wed Sep 06, 2006 7:04 pm
by cdvma
So I got a GM 3 bar MAP and I gotta scale it so I don't get CEL codes. Anyone else out there with any idea where the MAP scaling table is?
Someone with street/pro tuner out there that can give a screenshot of the stock values so I can do an intelligent search?
Re: MAP sensor scaling hunt
PostPosted: Mon Sep 11, 2006 9:41 am
by ride5000
cdvma wrote:So I got a GM 3 bar MAP and I gotta scale it so I don't get CEL codes. Anyone else out there with any idea where the MAP scaling table is?
chris, if you haven't already tried it, you might have better luck with making a def file using xmlwrite.
-ken
PostPosted: Mon Sep 11, 2006 9:48 am
by cdvma
I have not tried that yet. Is xmlwrite around here somewhere?
PostPosted: Mon Sep 11, 2006 12:23 pm
by Freon
Post your rom if you want help with XMLs or finding maps. There is no way for us to help you if you don't do this.
PostPosted: Mon Sep 11, 2006 2:24 pm
by cdvma
Freon wrote:Post your rom if you want help with XMLs or finding maps. There is no way for us to help you if you don't do this.
This is the USDM '02-'03 section ;)
I'll try XMLWrite tonight if I have a chance.
PostPosted: Mon Sep 18, 2006 6:03 pm
by cdvma
So I used xmlwrite and there is no map sensor scaling table that I could see. Is anyone aware of one in ANY 2002 or 2003 image?
PostPosted: Thu Oct 12, 2006 6:18 am
by ride5000
there's one in mine. when i get back to my laptop i'll get you the offsets.
PostPosted: Thu Oct 12, 2006 6:26 am
by cdvma
Day late and a dollar short :(
I already cut the wiring harness and am running dual MAP sensors. But the info is still useful, thanks Ken.
PostPosted: Thu Oct 12, 2006 12:13 pm
by ride5000
heheh
over the w/e i cut my harness and am driving both the oem ecu and the utec from the oem map. i am happy to report that it looks like the input impedance is high enough on both devices to avoid loading the signal down.
incidentally the oem reads about 1psi lower than the utec at full scale (23psi).
