cobb maps!!
can it be possible to read a car with a cobb map installed and then reflash it into my car???
Forums for ECU reverse engineering and modification
http://forums.openecu.org/
Yes, that's possible. You'll only get the "base" map, although whichever AP that was orginally used to install the maps on the other car would probably think it's married to your car, too.Stealth wrote:can it be possible to read a car with a cobb map installed and then reflash it into my car???
Jon [in CT] wrote:Yes, that's possible. You'll only get the "base" map, although whichever AP that was orginally used to install the maps on the other car would probably think it's married to your car, too.Stealth wrote:can it be possible to read a car with a cobb map installed and then reflash it into my car???
Stealth wrote:Jon [in CT] wrote:Yes, that's possible. You'll only get the "base" map, although whichever AP that was orginally used to install the maps on the other car would probably think it's married to your car, too.Stealth wrote:can it be possible to read a car with a cobb map installed and then reflash it into my car???
so that means it will tune it two right??
Cobb distributes its maps without charge or license. I recall a post by Trey where he actually invited people to try and hack them (http://www.wrxforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=11;t=000108#000008). Nobody mentioned StreetTuner in this thread until your post and the original poster was must likely referring to AccessPort, a piece of hardware.ahains wrote:[IANL disclaimer] Some folks obviously suggest that using cobb's maps without purchasing an AP is legal (if perhaps immoral/shady depending on your point of view). I do not think however that anyone would suggest that using a non-purchased copy of Street Tuner is legal. That is software piracy plain and simple. Maybe that is not a concern for you, but I point it out anyway.
Jon [in CT] wrote:Nobody mentioned StreetTuner in this thread until your post and the original poster was must likely referring to AccessPort, a piece of hardware.
Stealth wrote:so that means it will tune it two right??
Stealth wrote:well anyone know were i can get a similar map of a stage 2 or who has made one??
