cobb maps!!
cobb maps!!
Postby Stealth » Mon Jul 31, 2006 7:24 am
can it be possible to read a car with a cobb map installed and then reflash it into my car??? :?
Stealth
Postby MDTURBO » Mon Jul 31, 2006 7:43 am
doubt it. Cobb overwrites portions of the program logic to prevent this.
MDTURBO
Postby Stealth » Mon Jul 31, 2006 8:31 am
what about ecutek or Utec?
Stealth
Re: cobb maps!!
Postby Jon [in CT] » Mon Jul 31, 2006 9:06 am
Stealth wrote:can it be possible to read a car with a cobb map installed and then reflash it into my car??? :?
Yes, that's possible. You'll only get the "base" map, although whichever AP that was orginally used to install the maps on the other car would probably think it's married to your car, too.
Re: cobb maps!!
Postby Stealth » Mon Jul 31, 2006 10:12 am
so that means it will tune it two right??
Stealth
Re: cobb maps!!
Postby ahains » Mon Jul 31, 2006 12:38 pm
That should work fine - it should be a 100% identical clone, software-wise.
But why would you want to use Street Tuner over the free apps? Do you like its functionality better?
[IANL disclaimer] Some folks obviously suggest that using cobb's maps without purchasing an AP is legal (if perhaps immoral/shady depending on your point of view). I do not think however that anyone would suggest that using a non-purchased copy of Street Tuner is legal. That is software piracy plain and simple. Maybe that is not a concern for you, but I point it out anyway.
ahains
Postby Stealth » Thu Aug 03, 2006 9:11 pm
i hear ya so its illegal :cry:
Stealth
Re: cobb maps!!
Postby Jon [in CT] » Fri Aug 04, 2006 4:33 am
ahains wrote:[IANL disclaimer] Some folks obviously suggest that using cobb's maps without purchasing an AP is legal (if perhaps immoral/shady depending on your point of view). I do not think however that anyone would suggest that using a non-purchased copy of Street Tuner is legal. That is software piracy plain and simple. Maybe that is not a concern for you, but I point it out anyway.
Cobb distributes its maps without charge or license. I recall a post by Trey where he actually invited people to try and hack them (http://www.wrxforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=11;t=000108#000008). Nobody mentioned StreetTuner in this thread until your post and the original poster was must likely referring to AccessPort, a piece of hardware.
Re: cobb maps!!
Postby ahains » Fri Aug 04, 2006 6:30 am
Jon [in CT] wrote:Nobody mentioned StreetTuner in this thread until your post and the original poster was must likely referring to AccessPort, a piece of hardware.
I was assuming this was referring to StreetTuner:
Stealth wrote:so that means it will tune it two right??
But maybe this was just referring to map switching, not actual tuning? I was obviously assuming the latter.
ahains
Postby Stealth » Sat Aug 05, 2006 8:53 pm
well anyone know were i can get a similar map of a stage 2 or who has made one??
Stealth
Postby ahains » Sun Aug 06, 2006 3:33 am
Stealth wrote:well anyone know were i can get a similar map of a stage 2 or who has made one??
Go register at http://www.osecuroms.org/ and you will be able to browse the downloads there. You can apply the stage 2 changes there to your base map if they don't have a directly useable map for you.
ahains
Postby thejean » Mon Dec 04, 2006 11:46 am
When I had my AP, I uploaded all of the Cobb basemaps to my ECU and then downloaded the rom images to my laptop. I then unmarried my AP and loaded up other roms, including some that did not belong to my car. Then I switched back to the Cobb maps from the laptop using ecuflash. Every single map/rom image worked just fine. There were no lock-outs or anything the prevented me from switching between maps on the fly. Sure, while Cobb maps are loaded your car things it's "married" :lol: but the maps are easily over written (including the marriage) by any other rom image. Of course, I am protuned so I'm no longer using the Cobb maps at all.
thejean
