Modifying injector scaling and MAF curve...
I've been trying to modify my A4SGE01C ROM to change injector and MAF scaling, but I've been having some issues...
Since I run a Perrin BigMAF, I computed updated values for the MAF curve by multiplying the air flow values by 1.16. Also, I increased my injector value to 800CC (running modified WRX injectors).
My problem is when using an image modified with these two changes, my car runs exceptionally lean. It idles around 16.5:1 - 17.1:1 AFR
I ASSUMED modifying these two areas would be enough to allow the ECU to properly compute its fueling, etc., but based on my experience, it seems like I'm missing something. Any advice?
