Subaru Impreza Group N Prodrive
I'm working on a Subaru Impreza STI '99 Rally Group N.
The car has PRODRIVE ECU maped for GRAVEL and Fuel = ELF TURBO PLUS and inside EPROM by Prodrive ver. G2.32. The Eprom is 27C256.
I read the file inside and i'm trying to modify it.
Can you please help me with the maps, the FUEL, IGNITION, and BOOST map.
The WINOLS finds 1 map 12x9, looks like FUEL, but i think it is not correct. I think the boost is 12x12.
The problem with the car is that it has veri short rpm range max torque.
At 3000 rpm = 180 Nm
3500 rpm = 366 Nm
4000 rpm = 300 Nm
4500 rpm = 160 Nm
5000 rpm = 80 Nm
And that is very bad!
I'm sending the file and hope to help me!
Best Regards,
3500 rpm = 366 Nm
4000 rpm = 300 Nm
4500 rpm = 160 Nm
5000 rpm = 80 Nm
Best Regards,
