2002 ECU in a 2003?
2002 ECU in a 2003?
Postby bluesubaru » Thu Jun 08, 2006 7:45 am
Can I flash a 2002 ECU with a 2003 ROM and use it in my 2003 MT?
bluesubaru
Re: 2002 ECU in a 2003?
Postby x99percent » Thu Jun 08, 2006 11:48 am
bluesubaru wrote:Can I flash a 2002 ECU with a 2003 ROM and use it in my 2003 MT?
Just use a 2002 ROM in the 2002 ECU. Should cause no issues in a 2003 car.
x99percent
Postby bluesubaru » Fri Jun 09, 2006 11:19 am
...but can I flash a 2003 ROM to a 2002 ECU? The hardware is said to be the same (or close enough).
bluesubaru
Postby Jon [in CT] » Fri Jun 09, 2006 12:13 pm
bluesubaru wrote:...but can I flash a 2003 ROM to a 2002 ECU? The hardware is said to be the same (or close enough).
No. Hardware isn't the same. The 2003 ECU supports a solenoid that isn't present on the 2002 WRX.
Postby west_minist » Fri Jun 09, 2006 1:14 pm
But even if that was the case, why would you want to do that?
Postby Jon [in CT] » Fri Jun 09, 2006 2:54 pm
On second thought, you can flash a 2003 ROM onto a 2002 ECU and use it in a 2003 WRX without the MIL commanded ON if you can disable this trouble code: P1446 - Fuel Tank Sensor Control Valve Circuit Low.
I, like others, wonder why.
Postby ECUPancakes » Fri Jun 09, 2006 3:15 pm
Jon, what exactly does that solenoid do?
ECUPancakes
Postby Jon [in CT] » Fri Jun 09, 2006 7:16 pm
ECUPancakes wrote:Jon, what exactly does that solenoid do?
It's described on p. 12 of the attachment.
BTW, it was dropped midstream during MY05 Legacy production:
http://www.thel7.com/TSB/11-75-05.pdf
MSA5T0419A36257 Evaporative Emission Control System.pdf
(263.17 KiB) Downloaded 512 times
Postby bluesubaru » Mon Jun 12, 2006 10:39 am
west_minist wrote:But even if that was the case, why would you want to do that?
because I can get a 2002 ECU for cheap. I want to keep my stock 2003 ECU un-modified and use a 2nd ECU (the 2002) in the car and mod that. I would rather work with 2003 code than 2002 code since that is what my car is.
Is that better? I don't know. But I would do it if it is possible.
bluesubaru
Postby x99percent » Mon Jun 12, 2006 11:48 am
Just use the 2002 code on the 2002 ECU. It will work just fine.
Hell, with E**TeK reflashes, people typically run 2002 ROMs on 2003 ECUs (in 2003 cars) to enable boost map switching.
x99percent
Postby xswrex » Mon Jun 12, 2006 11:33 pm
x99percent wrote:Hell, with E**TeK reflashes, people typically run 2002 ROMs on 2003 ECUs (in 2003 cars) to enable boost map switching.
+1
xswrex
