Questions about Gabedudes Stage 1 06-07 map
Hi,
I'm brand spanking new to all this tuning thing, but have done a bunch of homework and am gearing up to reflash Gabedudes Stage 1 06-07 map on my MY06 ADM wrx in New Zealand. I got the map from RomRaider, but they won't let me post there without approval, and no-one seems to respond to my requests for approval, so here I am.
I've read my stock rom, and have the following differences which I'm concerned about. Hoping someone could shed some light?
1) CL Fueling Target Compensation (Load) -- Small difference, do I need to change?
2) Cranking Fuel Injector Pulse Width A (ECT) --small changes, User Level = Debug, do I need to modify?
3) Min Primary Base Enrich 2 Initial Start 1A --DEBUG USER LEVEL, only diff at -10degC, prob don't change?
4) Min Primary Base Enrich 3 Initial Start 1A --DEBUG USER LEVEL, only diff at -10degC, prob don't change?
5) Base Timing Alternate (ECT) --80-110deg big diffs, but Debug Level table, do I need to change?
6) Gear determination Thresholds --different, but Romraider suggests these arn't changed from stock unless gear ratios changed
Thanks for any help guys!
Chris
Chris
