need help please.....ecuflash
Postby dohoss » Fri Jan 18, 2013 7:34 am
need alittle help...i flash my 03 wrx fine ...but i have a friends car that he just purchased. 2008 wrx.
i tryed flashing and i was able to pull the map off but not able to reflash.im getting a error ..heres the log.
and now i cant get anything to work.
i also tryed to plug in the green test cables on passenger side buy the ecu..they were unpluged..figured it didnt go in to test mode. i also shut the key off though when it made the error.. so im guessing brick maybe.
i would like to know about the error log.....thanks
[09:41:17.723] EcuFlash Version 1.44.3721
[09:41:17.733] OS Version Windows 7
[09:41:17.733] Qt Version 4.8.0
[09:41:17.743] 63 memory models read.
[09:41:17.743] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[09:41:18.104] 615 ROM metadata models scanned.
[09:41:18.104] checksum module "subarudbw" loaded.
[09:41:18.104] checksum module "mitsucan" loaded.
[09:41:18.104] checksum module "mitsuh8" loaded.
[09:41:18.104] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[09:41:18.104] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[09:41:18.104] flashing tool "wrx02" loaded.
[09:41:18.114] flashing tool "wrx04" loaded.
[09:41:18.114] flashing tool "sti04" loaded.
[09:41:18.114] flashing tool "sti05" loaded.
[09:41:18.114] flashing tool "mitsukernel" loaded.
[09:41:18.114] flashing tool "mitsukernelocp" loaded.
[09:41:18.114] flashing tool "mitsubootloader" loaded.
[09:41:18.114] flashing tool "shbootmode" loaded.
[09:41:18.124] flashing tool "shaudmode" loaded.
[09:41:18.124] flashing tool "subarucan" loaded.
[09:41:18.134] flashing tool "subarucand" loaded.
[09:41:18.134] flashing tool "mitsucan" loaded.
[09:41:35.259] AZ1E401A (324 tables) inheriting 32BITBASE (893 tables)
[09:41:35.479] 1048576 byte image read.
[09:41:35.589] using metadata XML ID AZ1E401A from file C:/Program Files/OpenECU/EcuFlash/rommetadata/subaru/Impreza WRX/AZ1E401A.xml
which inherits XML ID 32BITBASE from file C:/Program Files/OpenECU/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml
[09:42:22.370] J2534 API Version: 04.04
[09:42:22.370] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:42:22.370] Device Firmware Version: 1.12.3688
[09:42:22.370] Device Serial Number: TABwKRLX
[09:42:24.246] kernel get version
[09:42:24.667] SSM2 init
[09:42:24.887] interface close
[09:42:24.907] interface close
:roll:
dohoss
