05 sti roms almost duplicates
Postby gregsachs » Tue May 09, 2006 11:22 am
Was looking at the two 05 sti roms posted here, one from colby and one from justin, and they are _almost_ identical. Differences are here:
00000FF8 | 90 96 |justin's rom 37014 dec
00000FF8 | 91 95 |colby's rom 37269 dec
what are the odds this is the ecu serial number/vin or similar?
Also, looking at the offsets posted elsewhere, the two 2005 sti revisions have the maps largely laid out the same, except for the following:
AJ930 8791
Fine Ign Learning Advance Time Interval 000C8490
Maximum Knock Retard 000C8688
Knock Retard Decrement - Gamma F 000C868C
Knock Retard Increment - Alpha F 000C8690
Knock Detection RPM Range 000C873C
Coarse Ign Learning RPM Range 000C8768
Coarse Ign Learning Load Range 000C8778
Fine Ign Learning Max Advance 000C87BC
Fine Ign Learning Max Retard 000C87C0
Fine Ign Learning Advance Magnitude 000C87C4
Fine Ign Learning RPM Range 000C87C8
Fine Ign Learning Load Range 000C87D8
Fine Ign Learning Map Load Columns 000C87E8
Fine Ign Learning Map RPM Rows 000C87F8
Fine Ign Learning Retard Magnitude 000C8810
Sel Mon ID 000CC694
AJ931 8792:
Fine Ign Learning Advance Time Interval 000C84E0
Maximum Knock Retard 000C86D8
Knock Retard Decrement - Gamma F 000C86DC
Knock Retard Increment - Alpha F 000C86E0
Knock Detection RPM Range 000C878C
Coarse Ign Learning RPM Range 000C87B8
Coarse Ign Learning Load Range 000C87C8
Fine Ign Learning Max Advance 000C880C
Fine Ign Learning Max Retard 000C8810
Fine Ign Learning Advance Magnitude 000C8814
Fine Ign Learning RPM Range 000C8818
Fine Ign Learning Load Range 000C8828
Fine Ign Learning Map Load Columns 000C8838
Fine Ign Learning Map RPM Rows 000C8848
Fine Ign Learning Retard Magnitude 000C8860
Sel Mon ID 000CC6E4
Not sure if more code got inserted or... These are all 1d maps, the 2 and 3d maps are all using the same offsets.
gregsachs
