2008 EDM Subaru Impreza WRX XML definition needed
Postby SeregaWRC » Wed May 18, 2011 6:43 am
The problem with me is, ECU won't read the callibration file. Please suggest how to cope with the problem. Thanks everybody in advance. Here are the detailed data:
2008 EDM Subaru Impreza WRX 2.5L Turbo MT ECU ID 5142584007 Sistem ID A2101101
SeregaWRC
Re: 2008 EDM Subaru Impreza WRX XML definition needed
Postby radsdau » Wed May 18, 2011 4:09 pm
Please post the stock ROM.
Postby SeregaWRC » Wed May 18, 2011 11:49 pm
Please tell me where this informations can be found :shock:
SeregaWRC
Postby radsdau » Thu May 19, 2011 2:56 pm
Ok: Use your OpenPort2 cable and ECUFlash to read the ROM from your car. If the ROM code is not recognized, choose the ECUFlash option that still allows you to save the ROM file. That's the file to post here.
MY08 should be CAN and probably doesn't require the green test mode connectors to be linked, but it doesn't hurt, especially if you're having trouble.
Postby SeregaWRC » Fri May 20, 2011 7:26 am
Thank you very much for your advice! A little later, try and write what happened
SeregaWRC
Postby SeregaWRC » Fri May 20, 2011 9:50 am
Hooray! Success! I understood everything. Thank you very much. I enclose a ROM.
By the way green test mode connectors do not connect, and so everything works.
WRX 2008 EDM.hex
(1 MiB) Downloaded 1142 times
SeregaWRC
Postby radsdau » Sun May 22, 2011 3:54 pm
Good to hear, well done.
AZ1E400U: based on AZ1E400C. ROMRaider supports this ROM.
Postby SeregaWRC » Mon May 23, 2011 6:45 am
OK. Thank you! I'll try and write about the result.
SeregaWRC
Postby SeregaWRC » Tue May 24, 2011 11:07 pm
I tried it and here's the result:
ECUflash and ROMRaider supports this ROM, but the Learning View is not connected to the ECU.
Interestingly, the ECUflash started working only when I installed it on another laptop. :?:
SeregaWRC
Postby radsdau » Wed May 25, 2011 3:35 pm
Learning View has its own set of defs (internally defined) afaik, so it's likely just not supported.
I don't know why installation on another laptop fixed it. I presume something went wrong with the Metadata directory settings.
