Subaru bricked ecu :(
Sat May 14, 2011 2:08 pm
by evoX
I have reflashed the ecu on a Subaru STI MY08 2.5 (EDM), and once it blocked when flashing the ECU at the beginning of flash, now the car does not start and I cannot flash any other map. I have replaced the ECU from a different Subaru same model, but the immobilizer does not let me start the engine.
Re: Subaru bricked ecu :(
Sun May 15, 2011 3:45 pm
by radsdau
The first ECU is bricked. Send it to Tactrix if you are in the US, and they can sort it for you. See their website.
The second one needs to be security coded by a Subaru dealer before it will run the car.
Sun May 15, 2011 3:49 pm
by evoX
I am in Europe
The subaru dealer told me that he cannot do anything and that they must send the ECU to Subaru in Japan in order to fix it.
Sun Jul 10, 2011 12:12 am
by Calin
Have you solved your problem with the bricked ECU?
Maybe I can help you.
Sun Jul 10, 2011 7:48 am
by asids
I can help you to get work second ECU. I need both ECUs and then I can send you working one and later try to repair also bricked ecu.
BR,
Andris.
Sun Jul 10, 2011 2:52 pm
by evoX
Not yet
