05 WRX 5sp Need Help tuning
Postby sti2686 » Sun Apr 03, 2011 9:05 pm
Yes this is my own may its on a 2005 wrx
DW 650cc injectors
Topmount
turboback
Fujitsu Intake
vf39
Having trouble getting the a/f to come down early when boost come on. I have tried everything messing with fuel tables, injector size and latency, and maf. If I change the maf anymore it will bog at part throttle and still not come on any fast. Even tried increasing the tip in. I have included a log and the map. Help would be great even on timing suggestions. I know its still pretty rich up top but I can work on that once I get the other part down will shoot for 11-11.3
romraiderlog_20110403_021651.csv
(2.89 KiB) Downloaded 798 times
04.02.11tunetrial.hex
(160 KiB) Downloaded 824 times
sti2686
Re: 05 WRX 5sp Need Help tuning
Postby absubtle » Wed Apr 06, 2011 8:23 pm
Hopefully, you have saved almost every change. Go back quite aways and change latency, add 5%. Test, keep going. Doesn't matter if everything else gets alittle off. Just see. Last time you changed spark plugs???
Absubtle
CO
absubtle
Postby absubtle » Wed Apr 06, 2011 8:28 pm
BUT, as my professional opinion, is there is a suction leak, if at the o-ring, of the MAF sensor, or close by. OR a poorly engineered suction pipe, w/ the MAF placed is a turbulence area or sized-wrong. I see this w/ front mounts, but since you are top mount, may not be a suction leak, but a BOOST LEAK.
Absubtle
CO
Sorry been tuning for 11 years, OpenSource for 5 years. I have a AWD/2w dyno, eddy current. I have 800+ different customer's roms for Subaru, alittle less w/ Evo.
Sounds like an Ebay suction or an incorrect MAF placement/sizing.
Replace w/ stock suction pipe w/ stock MAF housing, retest.
absubtle
Postby sti2686 » Tue Jun 21, 2011 3:23 am
exactly what was posted above, also look at your fuel transition delays and 0 them out I have found this to help
sti2686
