MY06 Impreza 2.5 STI (EURO) [AL340-2190] 6MT offsets
Postby DarkECU » Tue Apr 25, 2006 3:12 pm
Edward wrote:I don't know if this is the right place to post this but I've attached the file from my MY06 Impreza 2.5 STI (EURO) [AL340-2190] 6MT.
Found this in the file:
4a rA8DH200Z 46VEU Sti
Corp DENSO 2005
PF 23VH4T 80m Ver1.51r1
<ecus>
<ecu_struct id="A8DH200Z" type="AL340-2190 EURO STI">
<map name="7A4A8 T.Dyn. AIT Comp - Proportional" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0720" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0730" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A4BC T.Dyn. AIT Comp - Integral Negative" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0734" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0744" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A4D0 T.Dyn. AIT Comp - Integral Positive" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0748" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0758" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="17A4E4 Pri Wastegate Duty AIT Comp." type="2" active="1">
<rows count="0" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00000000" power="2" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00000000" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A4F8 Pri Wastegate Duty AIT Comp." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0768" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C07A8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A534 Pri Wastegate Cool Temp Comp" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C06E0" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0858" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A548 Pri Wastegate Cool Temp Comp" type="2" active="1">
<data offset="#000C0868" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A55C Desired Boost Cool Temp Comp" type="2" active="1">
<data offset="#000C0878" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A570 Desired Boost Cool Temp Comp" type="2" active="1">
<data offset="#000C0888" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A584 Boost Atmo Comp RPM Constant" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0898" inc_value_offset="#3C800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C08A8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A598 Boost Atmo Comp RPM Constant" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C08AC" inc_value_offset="#3C800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C08BC" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A5AC Turbo Dynamics Proportional Component" type="2" active="1" help="" level="0">
<rows count="9" offset="#C08C0" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#C08E4" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A5C0 Turbo Dynamics Integral Negative" type="2" active="1" help="" level="0">
<rows count="9" offset="#C08F8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#C091C" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A5D4 Turbo Dynamics Integral Positive" type="2" active="1" help="" level="0">
<rows count="9" offset="#C0930" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#C0954" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A5E8 Boost Atmo Comp RPM Multiplier" type="2" active="1" help="" level="0">
<rows count="4" offset="#C0968" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#C0978" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A5FC Boost Atmo Comp RPM Multiplier" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0980" inc_value_offset="#37800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0990" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7AA20 Veh. Speed based Throttle Angle Limiter" type="2" active="1">
<rows count="2" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DB83C" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DB844" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A7B8 Idle Air Flow Map - Cool. Temp Based" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1364" inc_value_offset="#3B960000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C13A4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A7CC Idle Engine Load Map - Cool. Temp Based" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C13C4" inc_value_offset="#38800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C1404" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A81C Merv: Idle Speed Coolant Comp ?" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1294" inc_value_offset="#3B800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C14A4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A7A4 Front O2 Atm P Comp" type="2" active="1" help="" level="0">
<rows count="4" offset="#C134C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#C135C" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7B384 Delayed Open Loop Fuel Throt Thresh." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C6820" inc_value_offset="#3EFA0000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C6860" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7B820 Delayed Open Loop Fuel Load Threshold" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C70B4" inc_value_offset="#40800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C70F4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7B948 Throttle Delta Fuel Comp. (Delta)" type="2" active="1">
<rows count="18" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C7588" inc_value_offset="#40800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C75D0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7B95C Throttle Delta Fuel Comp. Coolant Temp." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C6508" inc_value_offset="#39000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C75F4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7B97C Overrun fuel cut-off - fuelling restore RPM" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C6508" inc_value_offset="#3E480000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C7644" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7B990 Boost Limit" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C7664" inc_value_offset="#3F800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C767C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7BEC0 Minimum Ignition Timing" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C95EC" inc_value_offset="#3EB40000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C96AE" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7C190 AIT Based Hi Load Ign Addition" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C9AC4" inc_value_offset="#3EB40000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C9B04" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7C69C Overrun Desired Mass Air Flow" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000CAFC0" inc_value_offset="#3AC80000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000CB000" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7C6C4 Target Idle 1" type="2" active="1" help="" level="0">
<rows count="16" offset="#CAC5C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#CB038" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7C6D8 Target Idle 2" type="2" active="1" help="" level="0">
<data offset="#CB058" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7C6EC Target Idle 3" type="2" active="1" help="" level="0">
<data offset="#CB078" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7C700 Target Idle 4" type="2" active="1" help="" level="0">
<data offset="#CB098" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7C714 Target Idle 5" type="2" active="1" help="" level="0">
<data offset="#CB0B8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7C728 Target Idle 6" type="2" active="1" help="" level="0">
<data offset="#CB0D8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7CAC4 Minimum overrun throttle angle #1" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBA24" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBA3C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CAD8 Minimum overrun throttle angle #2" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBA44" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBA5C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CAEC Minimum overrun throttle angle #3" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBA64" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBA7C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CB00 Minimum overrun throttle angle #4" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBA84" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBA9C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CB14 Minimum overrun throttle angle #5" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBAA4" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBABC" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CB28 Minimum overrun throttle angle #6" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBAC4" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBADC" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CB3C Minimum overrun throttle angle #7" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBAE4" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBAFC" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CB50 Minimum overrun throttle angle #8" type="2" active="1">
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DBB04" inc_value_offset="#3F4CCCCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DBB1C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CD40 A Temp Sensor" type="2" active="1">
<rows count="30" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000CC1F4" power="2" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000CC26C" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CD4C MAF Sensor Scaling" type="2" active="1" help="" level="0">
<rows count="55" offset="#CC2E4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#CC3C0" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7CE1C Cool Temp Sensor Sc" type="2" active="1" help="" level="0">
<rows count="30" offset="#7D2A4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#7D31C" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7CE28 AIT Sensor Scaling" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000CCD38" inc_value_offset="#3EB40000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000CCD78" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="17A66C Initial Wastegate Duty A" type="2" active="1">
</map>
<map name="17A688 Initial Wastegate Duty B" type="2" active="1">
</map>
<map name="17A6A4 Initial Wastegate Duty C" type="2" active="1">
</map>
<map name="7A6C0 Initial Wastegate Duty D" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0AAC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0ACC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0AF4" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="17A6DC Max Wastegate Duty" type="2" active="1">
</map>
<map name="7A6F8 Max Wastegate Duty" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0BAC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0BCC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0BF4" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="17A714 Desired Boost A" type="2" active="1">
</map>
<map name="17A730 Desired Boost B" type="2" active="1">
</map>
<map name="17A74C Desired Boost C" type="2" active="1">
</map>
<map name="7A768 Desired Boost D" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0CDC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0CFC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0D34" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="17BBE4 Lo Det Fuel Map" type="2" active="1">
</map>
<map name="7BC00 Lo Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="19" offset="#C7B24" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#C7B70" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#C7BB8" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="17BC1C Hi Det Fuel Map" type="2" active="1">
</map>
<map name="7BC38 Hi Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="19" offset="#C7D24" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#C7D70" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#C7DB8" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="17C394 Ignition Base Map" type="2" active="1">
</map>
<map name="7C3B0 Ignition Base Map" type="3" active="1" help="" level="0">
<cols count="19" offset="#CA26C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#CA2B8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#CA300" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="17C340 Ignition Advance 1" type="2" active="1">
</map>
<map name="7C35C Ignition Advance 2" type="3" active="1" help="" level="0">
<cols count="19" offset="#CA058" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#CA0A4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#CA0EC" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="17C378 Ignition Advance 3" type="2" active="1">
</map>
<map name="17A634 WGD Atmo/RPM Comp 1" type="2" active="1">
</map>
<map name="7A650 WGD Atmo/RPM Comp 2" type="3" active="1">
<cols count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0A24" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C0A3C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C0A4C" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7CC28 Accel\Throttle Mapping" type="3" active="1">
<cols count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DC1B4" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="18" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000DC1F0" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000DC238" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7C458 IgnCor CT vs EngLd1" type="3" active="1" help="" level="0">
<cols count="16" offset="#C95EC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="2" offset="#CA5D8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#CA5E0" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="17D164 Intake Cam Advance" type="2" active="1">
</map>
<map name="7D180 Intake Cam Advance 2" type="3" active="1" help="" level="0">
<cols count="19" offset="#CDE0C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#CDE58" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#CDEA0" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A99C Calc Eng Ld Comp" type="3" active="1" help="" level="0">
<cols count="5" offset="#C1900" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="8" offset="#C1914" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#C1934" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="7A9B8 AirTemp vs AirFlow" type="3" active="1">
<cols count="11" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C195C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1988" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C19B8" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A9D4 RPM vs Throttle" type="3" active="1">
<cols count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1A3C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1A60" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C1A7C" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7A9F0 CPC Duty" type="3" active="1">
<cols count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1AFC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="5" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1B0C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C1B20" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="7AB10 Eng Ld vs RPM 13" type="3" active="1">
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1DC4" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="13" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000C1DFC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000C1E30" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="#C6380 Rev Limit" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C6380" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C63CC Speed Limiter" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C63CC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C5EBC Injector Flow Scaling" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C5EBC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#6C428 Enabled Diagnostic Trouble Codes" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#6C428" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C0665 Learnt Ign Count for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C0665" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C06C4 Learnt Ign Retard for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C06C4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C06C8 Advance Mult for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C06C8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C06CC Advance Mult for Boost Re-Enable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C06CC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C6178 Closed Loop Min Coolant Temp." type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C6178" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C617C Open Loop Per Gear RPM Thresholds Man." type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C617C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61A4 Open Loop Per Gear RPM Thresholds Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61A4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61CC Open Loop Stationary RPM Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61CC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61DC Open Loop Throttle Thresh Hi Alt. Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61DC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61E4 Open Loop Throttle Thresh Lo Alt. Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61E4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61EC Open Loop Throttle Threshold Manual" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61EC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61F0 Closed Loop Max Vehicle Speed" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61F0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61F8 Closed Loop Max EGT" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61F8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C61D4 Open Loop Hi/Lo Altitude Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C61D4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C6168 Fuel Map AdvMult Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C6168" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C9308 Knock Detection RPM Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C9308" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C9328 Coarse Ign Learning RPM Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C9328" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C9338 Coarse Ign Learning Load Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C9338" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C93A8 Fine Ign Learning Max Advance" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C93A8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C93B0 Fine Ign Learning Max Retard" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C93B0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C93AC Fine Ign Learning Advance Magnitude" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C93AC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C93C0 Fine Ign Learning Load Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C93C0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C9378 Fine Ign Learning Map Load Columns" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C9378" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C9388 Fine Ign Learning Map RPM Rows" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C9388" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C93B4 Fine Ign Learning Retard Magnitude" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C93B4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C028C MAP Sensor Scaling - Pressure Offset" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C028C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C0290 MAP Sensor Scaling - Voltage Multiplier" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C0290" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C5DBC Closed to Open Loop Delay Periods" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C5DBC" power="1" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C95B8 ## Beta - Minimum Hi Load Ign Addition" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C95B8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C95BC ## Beta - Maximum Hi Load Ign Addition" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C95BC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#C95C4 ## Beta - Min AdvMult for Ign Addition" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#C95C4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#1FFC Boot ROM Version" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#1FFC" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#B0 DTC Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#B0" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#6C4DC DTC Definitions" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#6C4DC" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5 Fine Ign Learning Load Column Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#7 Fine Ign Learning RPM Rows Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#7" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#CD208 Sel Mon ID" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#CD208" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
</ecu_struct>
</ecus>
DarkECU
Postby xswrex » Tue Apr 25, 2006 10:36 pm
If i read this right, a single address points to another structure in the ROM which describes the size/axis/data offsets!
Cool :wink:
xswrex
Postby Freon » Wed Apr 26, 2006 11:38 am
Wow, awesome. I think this may help me get past the problems I've been having creating the XML for my DBW STI. :dancingbanana:
I'm going to download that ROM and XML when I get home and see if I can translate it to my ECU somehow.
Postby Guest » Sat Jan 20, 2007 8:47 am
Hi,
How did you connect to the 2.5 EU STI with EcuFlash ?
What connectors did you connect? I have tried anything I could but it did not connect :cry:
Guest
Postby bobik » Tue Mar 06, 2007 10:35 am
is this is xml definition for AL 340 2190 ECU ?
bobik
