For some reason I can't read from a 2001 JDM STi ecu, I'm using EcuFlash v1.42 & openport tactrix 2.0, connecting the green test connectors & plugging the ecu power jumper, but still can't read from the ecu, even tough I had flashed several similar ecus using the same cable & software! I'm getting the following log/error message:
[08:27:30.036] J2534 API Version: 04.04
[08:27:30.036] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[08:27:30.036] Device Firmware Version: 1.10.2658
[08:27:33.581] denso02_bootloader_cmd_start
[08:27:34.853] denso02_bootloader_cmd_start
[08:27:36.125] denso02_bootloader_cmd_start
[08:27:37.407] denso02_bootloader_cmd_start
[08:27:38.689] denso02_bootloader_cmd_start
[08:27:39.109] kernel get version
[08:27:39.420] interface close
[08:27:39.430] interface close
