Additional definitions
Cruise/NoCruise : FFFF8A5E
Switch-Intel3-Sport1-Sport#2 : FFFF611D
RPM - #FF6810 - float - tr/mn
Engine Load - #FF65D4 - float
Véhicule Speed - FFFF67E8 - float - km/h
RPM 2 - FFFF79C8 - float - tr/mn
battery - FFFF412C - float - Volt
Fine Cruise/NoCruise - FFFF6658 - float
Gear - FFFF69FC
Atmospheric Pressure - FFFF6A6C - float - *.001333224 - Bar
Calculated Base Pulse With - FFFF6F1C - float - *.001 - ms
Coolant Température - FFFF6540 - Float - C
Vehicle Stop/roll - FFFF85CC - on/off
Memory Start Coolant temperature - FFFF6544 - Float - °C
Min RPM Start Engine - FFFF8338 - float - rpm
Throttle Motor Duty - FFFF8758 - float - %
A/F Sensor 1 Current - FFFF40DC - float - mA
Mass Air Flow - FFFF65B0 - float - g/s
Vehicule Speed 2 - FFFF67EC - float - Kph
Ignition Total Timing - FFFF79C1 - float - Degree
Intake Air Temperature - FFFF6A70 - float - C
Mass Air Flow 2 - FFFF65AC - float - g/s
Rear O2 Sensor - FFFF43F8 - float - Volt
Primary Wastegate Duty Cycle - FFFF5EDC -float - ms
Atmospheric Pressure - FFFF6A70 - float - /750 - Bar
Fuel Pump Duty - FFFF7DA4 - float - %
Tumble Valve Position Sensor - FFFF4028 - uint8 - /50
CPC Valve Duty Ratio - FFFF6B78 - float - % - *100
Clutch - FFFF61BA - on/off
Intake VVT Advance Angle Right - FFFF8B08 - float - degree
Intake VVT Advance Angle Left - FFFF8B0C - float - degree
Intake OCV Duty Right - FFFF8B60 - float - %
Intake OCV Duty Left - FFFF8B64 - float - %
Intake OCV Current Right - FFFF6610 - float - mA
Intake OCV Current Left - FFFF661C - float - mA
Neutral Position Switch - FFFF679B - 8 Bits - On/Off
Air Conditioning Switch - FFFF679F - 8 Bits - On/Off
Idle Switch - FFFF8023 - 8 Bits - On/Off
Ignition Switch - FFFF6798 - 8 Bits - On/Off
Accelerator Switch - FFFF6144 - 8 Bits - On/Off
Radiator Fan Relay #1 Switch - FFFF8816 - uint8 - On/Off
Radiator Fan Relay #2 Switch - FFFF8817 - uint8 - On/Off
